Jul 16, 2024 9:55 AM UTC
MS Power Automate
I am trying to connect DocuSign with Microsoft Power Automate to retrieve custom data (such as the envelope submission date, a certain value stated in an envelope, and the count of approvers) from an envelope and automatically fill out the custom data in a SharePoint list when the envelope is completed
Is there a way to achieve this?
Alexandre.Augusto
Jul 16, 2024 1:22 PM UTC
Hello, @User2020
You are welcome to the Docusign Community!
Take a look on this video:
If you would like to learn more about Docusign and Microsoft integrations.
Docusign University offers a free Learning Path for that.
Here the link, you click in Register using your same email/password used to login at your Docusign account:
https://dsucustomers.docusign.com/path/docusign-esignature-microsoft
I hope that helps!
Best,
Alexandre
Alexandre.Augusto
Hello, @User2020
I hope that helps!
Best,
Alexandre
Jul 31, 2024 12:31 AM UTC
Hi @User2020,
