Mar 10, 2023 11:33 PM UTC
If receivers of envelopes are going to use a mobile device to sign the required documents, do they need to download the DocuSign application first? If you click on the link in the email, the documents do not load correctly on a mobile device.
Mar 11, 2023 12:07 AM UTC
Recipients are not required to sign using the mobile app.
Sometimes envelopes sent with "Mobile-Friendly Viewing with Responsive Signing" enabled will have problems when being viewed on mobile devices.
You can disable this option in the envelope's advanced settings, detailed instructions on this process can be found. here:
Send a Responsive Document
