Mar 5, 2024 12:57 PM UTC
how to have long lived docusign embedded signing url in power automate
We are using DocuSign connectors in Power Automate to send documents for signature to recipients. I am using the "Generate embedded signing URL" connector. However, this link will expire once the recipient opens and closes the browser. If they reopen the URL, it shows the DocuSign page and indicates that the link has expired.
Kallool.Medhi
Jun 20, 2024 4:06 AM UTC
Here is an excellent blog post that talks about the solution approach that can be considered to achieve long-lived embedded signing URLs - https://www.docusign.com/blog/developers/long-lived-embedded-signing-urls.
Michael.Rave
Mar 5, 2024 3:09 PM UTC
@irfan908
In embedded singing the signing links expire after 300 seconds (5 minutes) and are one-time use only. You will need to generate a new signing URL each time the recipient wants to access the envelope. There is no option to extend the link expiration or access it multiple times.
How do you redirect the user to the embedded signing URL? The typical use case for Embedded Signing is that DocuSign eSignature will be embedded seamlessly into an existing web page, portal or application.
This DocuSign Support Article provides additional details on Embedded signing in general.
Mar 19, 2024 10:11 PM UTC
Hi @irfan908,
Kallool.Medhi
