Jun 27, 2024 2:13 PM UTC
Help! QuickBooks unable to connect to a remote server—How to fix!
I'm having trouble with QuickBooks being unable to connect to the remote server. This issue started after I changed some network settings on my computer. I've already checked my internet connection and firewall settings, and everything seems fine. Despite this, QuickBooks still can't establish a connection. Has anyone else faced this issue? Any suggestions or solutions would be greatly appreciated.
Jun 27, 2024 2:32 PM UTC
Hey,
QuickBooks unable to connect to a remote server can be frustrating, but there are steps you can take to resolve this issue. Start by checking your internet connection to ensure it's stable and working properly. Next, verify your firewall and antivirus settings to ensure they are not blocking QuickBooks from accessing the internet. If everything seems fine, try restarting your computer and router to refresh network connections. It's also helpful to update QuickBooks to the latest version available, as updates often include fixes for connectivity issues. If the problem persists, consider contacting QuickBooks support for further assistance and troubleshooting tailored to your specific setup.
Jun 27, 2024 2:35 PM UTC
@Markjones986
What  network settings did you change?
Make sure that you are using the latest version of QuickBooks. Updates often include bug fixes and improvements.
Jul 11, 2024 2:51 PM UTC
Hi @Markjones986,
