lcornwell
Troubleshooter
Troubleshooter
May 29, 2024 5:46 PM UTC
DocuSign with Power Automate
Good afternoon everyone!
Is anyone here using Power Automate w/ DocuSign?  If so, what are you using it for?  I was asked to look into this and while I think it could work for onboarding employees, that’s really the only scenario I can think of.
Thanks in advance,
Lindsay
May 29, 2024 8:26 PM UTC
Power Automate can be used at many stages of the document lifecycle. We are mostly using Power Automate after the document is signed. Here are the functionalities we implement:
  • Document Storage and Archival
  • Update Records in Databases and CRMs
  • Generate Follow-Up Tasks from other applications
  • Data Extraction and Analysis
lcornwell
Troubleshooter
lcornwellTroubleshooterAuthor
Troubleshooter
May 30, 2024 11:15 AM UTC
Thank you John, this has been helpful.  I have a few additional questions.  As a background, I’m the DocuSign admin here, but came from IT in Healthcare.  So I understand the IT side really well, I’m still learning the banking side of things.  I apologize if some of these questions are menial.
  • Are you archiving the documents in SharePoint or another application?
  • What are you using as your CRM (we use Salesforce)?
  • What types of fields are you updating with Power Automate?
  • What types of follow-up tasks are you generating and in which apps?
Thanks in advance for your help, it’s much appreciated!
Lindsay
May 31, 2024 10:12 PM UTC
Hi Lindsay - Happy to help.  I am an experienced DocuSign Admin with nearly a decade of expertise in Financial Services and Staffing.  I currently managing DocuSign integrations and workflows, while actively resolving user issues and optimizing document management processes.
  • Archiving completed envelopes in SharePoint and OpenText. I have also used OnBase
  • We use Salesforce too.
  • We update fields such as signer information, status updates, and document metadata.
  • For follow-up tasks, we are generating notifications, reminders, and task assignments in applications like Microsoft Teams, Outlook, and SharePoint.
Jun 19, 2024 12:20 AM UTC
Hi @lcornwell,
