May 10, 2024 7:51 AM UTC
There's no direct connector with Power BI, so you might need to use Docusign API or use a 3rd party connector like CDATA, Automate.io, Tray.io. In case of using Docusign API, you can find all the documentation about connecting and implementing Docusign API on the Developer Center (https://developers.docusign.com/). You might be able to pull the data by calling Docusign API from Power BI.
