Conversation Starter
Dec 29, 2025 7:34 AM UTC
Idea Submitted
Workflow Builder (formerly Maestro) Workflow Needs More Features to attract more customers
Categories:Workflow Builder
Hi Team,
I am feeling DocuSign Workflow Builder (formerly Maestro) is not helping much customers when it comes to real life use cases, recently I have posted my post on community, however I am looking for feature mentioned below:
  1. Ability to allow to add more than one templates, as of now it allows only one template, for e,g. I want to dynamically combine multiple templates on the basis of various choices for e.g. if Investor age > 65, add Senior Attestation Template with main template and send for signature
  2. If Investor selects multiple sponsors, then it should add only those templates
  3. Radio and Checkbox buttons must have ability to map with dropdown options from webforms. I have a template which as radio buttons and checkboxes and I want to collect data from webforms where I want to show drop downs for same options rather using radio buttons, once I have data in webform, I want to map dropdown selected option ( text ) with template’s radio or checkboxes values so it should pre populate selection , this is lacking at the moment
  4. Send Email and Send Invite with Dynamic Field Population, if I want to send email and in the subject and body want to populate data from webforms variables, I am unable to use them, hence I am having limited ability to just use static text but cannot build body and subject dynamically
Feb 26, 2026 11:22 AM UTC
5. Another great feature would be the ability to send multiple created documents. The e-signature template is filled in using the web form, and then not just one e-signature template is sent, but several. The display shows multiple templates, but only one can be selected.
6. It would also be great to have a workflow start step. In an existing workflow, a true/false condition would be met, triggering another Maestro workflow.
