Digital Collaborator
July 10, 2024
Parked
When setting up templates with custom fields allow for expansion/reduction of the space to allow for custom text merges and edit bulk send items before final send
Categories:eSignature
We have found that the templates in e-signature, custom merge fields do not act as text fields as far as formatting and spacing.  You have to guess on how much space you will need to accommodate the longest known delimiter.  So if you are merging a client’s firm name into a sentence as a custom field and the first client is “AD Bank” and the second client is “John Jacob Jingleheimer-Schmitt Broker Dealers Incorporated” you would have to format the spacing in your template to accommodate the second name which would leave a ton of space for AD Bank’s document.
If you format for less than the space on the longest name, then the longer name overprints on the text of the file.
The merge fields should act as text as far as the template documents are concerned, either expanding or shrinking to fit the text and allowing the existing text on the page to move along with the merged text.
This has caused issues with bulk sends where we sent out thousands of documents with multiple merge fields that varied in size.
It looks very unprofessional and is not transparent when using the bulk send feature.  There should be a way to review the bulk send items before they are sent to accommodate these types of errors if not.
Thanks for sharing this idea with us, ​@newtoclm  We’ve reviewed it and appreciate the thought behind it.
At this time, we’re not planning to pursue this request, so we’ve marked it as parked.
While it’s not on our current roadmap, ideas like yours help inform future direction if priorities change.
Thanks again for contributing your input.
Ma.Cassandra | Docusign Community Moderator
Delivered→Parked
