Delivered
Specific setting for documents (FS) which require filing with authorities in Luxembourg
Categories:Admin Tools
Dear DS developers,
Luxembourg has a large fund industry.
Each year many documents (especially Financial statements) need to be filed with local authorities.
Their requirement is a PDF/A format and a blank space of 35mm (about 1.5inch) of fully blank space on the first page of the Financial statement.
This requires time consuming “amending” of the signed document to move the DS reference on the first page which is in the way.
It would be so very useful if the creator of the envelop could choose a “type of document” which allow repositioning of the signing reference before signature ie. at the bottom left or right corner and not top left ..
Many users do not have the option to maned their setting and/or in their position as Partners or Directors have no time to meddle with such options depending on the documents they receive.
Having such a feature or option at creator level would save many, many hours of document re-formatting across the entire country.
Thank you for your feedback.
Krgds,
Petra Lahr
​@Artep6509, we’re thrilled to share that this idea has been delivered!
Thank you for your feedback—it played a big role in shaping this feature. You can learn more about how to use it here:
Control Envelope ID Placement
Manually Place and Format the Envelope ID on a Document
Idea Submitted→Delivered
