mshealy
Established Contributor
February 19, 2025
Parked
esig web form-drop down field-dropdown options manual
Categories:Web Forms
When I create a field that is drop down, I have to add the dropdown options manually.  This is very time consuming with a field that holds 50 choices.  Need a way to have it load from a csv that can be stored within docusign or uploaded to the field/webform.
Thanks so much for sharing your idea with us ​@mshealy! We’ve reviewed it and really appreciate the thought behind it.
At this time, we’re not planning to pursue this request, so we’ve marked it as parked. While it’s not on our current roadmap, ideas like yours help inform future direction if priorities change.
In the meantime, if this is a template-based webform, the options will automatically populate if the picklist already exists in the template. For standalone forms, there isn’t currently a way to add options in bulk.
Thanks again for contributing your input.
Idea Submitted→Parked
