Idea Submitted
Allowing more Management settings in Templates
Categories:eSignature
As of know you can only disable the setting to edit the Subject line, private message and email all together in share template settings. I would think that it is beneficial so separate those options for in my case I just want to lock the subject line.
The same would go for editing recipients, I would like to leave a Cc locked at the end of the signing and the shared user would still be able to add or edit who the envelope would go to.
Thanks for submitting this idea, ​@esepulv15. We appreciate you taking the time to share it with us.
Our team is actively working through all submitted Ideas, and while there’s no update to share just yet on this one, we’ll follow up if there’s a status change. Thanks for your patience and input.
