Conversation Starter
March 12, 2024
MAX_CONNECT_CUSTOM_CONFIGURATION_FOR_ACTIVE_REST_PAYLOAD_EXCEEDED
  • March 12, 2024
  • 8 replies
  • 621 views
Error Message : '{"errorCode":"MAX_CONNECT_CUSTOM_CONFIGURATION_FOR_ACTIVE_REST_PAYLOAD_EXCEEDED","message":"Maximum number of active connect custom configurations for Rest Payload exceeded. Rest payload configurations[20] are exceeding or at the allowed limit[20]"}'.
please find the attached screenshot for the power automate flow setup.
please provide a solution so that I can use it to correct the flow. or please fix the bug.
Best answer by Michael.Rave
@RebekahG
The fix for Microsoft Power Automate has been deployed everywhere and issue has been officially resolved.
However, if you still have multiple DocuSign Connect configurations in your account right now, you need to delete them manually once, but Microsoft Power Automate will not create new duplicate configurations.
Best practice is to rename the configuration name in Power Automate, e.g. add a “V2” at the end and save it. Then you can remove all other DocuSign Connect configurations with the old name.
Michael.Rave
@rockand.roll
This is related to the current bug that Power Automat creates multiple connections in DocuSign Connect. When you hit the max. limit of 20, the flows will fail with the mentioned error message.
You can manually delete the multiple DocuSign Connect configurations in DocuSign eSignature Settings. This is a manual workaround until the bug has been fixed and the fix being released into the live systems.
March 13, 2024
Sure, that i have raised a case or ticket for the same.
please find the details below:
Case #: 13217315
Subject: MAX_CONNECT_CUSTOM_CONFIGURATION_FOR_ACTIVE_REST_PAYLOAD_EXCEEDED
Description: DocuSign Developer Account Number - Dev - EN: 25206293
Since i wasn’t able to raise a case without integration key. i have included a dummy key as integration key.
kindly please take this Case #: 13217315 on priority.
Thank You!
March 25, 2024
Hi @Michael.Rave
I’ve just encountered this same error. I receive the completed DocuSign form back via email but the flow no longer updates the envelope status on my SharePoint site.  Nor does it update the file with the final copy.
Do you recommend that I submit a ticket as well?
Thank you @rockand.roll for posting this!  I was getting pretty frustrated  😖
Michael.Rave
@RebekahG
March 25, 2024
Thank you @Michael.Rave ,
I’ve done just that and my flow is working again.  Just need to figure out how to get that completed file to replace the original file in my library.
Much appreciated!
Hi @RebekahG and @rockand.roll,
I would like to confirm if you need further assistance with this, feel free to let me know and I will gladly help you address the situation as soon as possible.
April 16, 2024
Hi @Christopher.Alpizar ,
My portion has been resolved, thank you both!
Hi @RebekahG,
I hope you are doing well. I am glad to hear that.
