Apr 30, 2024 8:32 AM UTC
Which plan is right for me
In my backend code  I am calling Docusign’s APIs to create envelope using template and then send it to customers for their signature.
I am confused as to which plan to choose from below.
Should I use Developer API ? if i choose eSignature can I not use docusigns APIs in my code?
Your help would be appreciated.
Alexandre.Augusto
Apr 30, 2024 1:18 PM UTC
Hello, @vaas070
Using an eSignature account plan includes use of APIs, so you will be able to create envelopes and templates via API, however depending on the volume of envelopes and additional features that you may need, I suggest to you call our Sales team so they can direct you to the right fit for your use.
I hope that helps.
Alexandre
Alexandre.Augusto
Hello, @vaas070
I hope that helps.
Alexandre
CrisZ
Apr 30, 2024 8:32 PM UTC
@vaas070 if you are a Docusign Partner developing an integration with our product, we have more details available at our Partner Portal. Please let me know if that is the case and I’ll guide you through it.
Best
Cristina
Cristina Z
May 15, 2024 1:02 AM UTC
Hi @vaas070,
