Mar 11, 2019 8:23 PM UTC
How do I get rid of envelope id and frame around signature on my document?
I've seen this question posted and answered before, but the options to fix it no longer exist. How do I get rid of these?
Mar 11, 2019 8:29 PM UTC
A DocuSign Admin can go to Admin Console, then Signing Settings, change the DocuSign Frame to "do not add frame", under the Signature section and Save. Here is a DocuSign article that explains more, look under the "Signature options" section...
https://support.docusign.com/en/guides/ndse-admin-guide-signing-settings
Mar 11, 2019 8:42 PM UTC
Thank you for answering. However, that option does not exist in my admin. 1
Mar 11, 2019 8:47 PM UTC
There are several possibilities why you are unable to see that option...
1) Your current DocuSign permission restrict access. If you are a full DocuSign Admin then this cannot be the reason.
2) Your Account plan does not include this feature or functionality.
3) The feature was not enabled by DocuSign. I have seen several scenarios where Accounts have been upgraded or features were not enabled at Account startup, even when a DocuSign Account should have that feature.
My suggestion is to create a DocuSign Support case indicating the missing functionality and checking to see if this can be enabled based on your Account plan feature set.
