Apr 26, 2024 1:13 PM UTC
sameorigin set when using Docusing JS for embedding
I am updating an embedded signing flow that uses a iFrame element on a page to use the Docusign JS method defined here (https://developers.docusign.com/docs/esign-rest-api/esign101/concepts/embedding/#docusign-js). I get the recipient URL and pass it to the following code:
var iframurl = "{{iframeUrl}}";
window.DocuSign.loadDocuSign('xxxx').then((docusign) => {
const signing = docusign.signing({
url: iframurl,
displayFormat: 'focused',
style: {
/** High-level variables that mirror our existing branding APIs. Reusing the branding name here for familiarity. */
branding: {
primaryButton: {
/** Background color of primary button */
backgroundColor: '#333',
/** Text color of primary button */
color: '#fff',
/** High-level components we allow specific overrides for */
signingNavigationButton: {
finishText: 'Custom Button Text',
/** 'bottom-left'|'bottom-center'|'bottom-right', default: bottom-right */
position: 'bottom-left'
/** Event handlers **/
signing.on('ready', (event) => {
console.log('UI is rendered');
signing.on('sessionEnd', (event) => {
/** The event here denotes what caused the sessionEnd to trigger, such as signing_complete, ttl_expired etc../ */
console.log('sessionend', event);
signing.mount('#agreement');
}).catch((ex) => {
// Any configuration or API limits will be caught here
console.log(ex);
“xxx” is set property just hidden for my post. “iframurl” is the envelope URL that I used to set on the iFrame elements src. When I use the DocuSign JS method, a new iFrame is created under a div with id “agreement”. “The src is then set to a different URL that the envelope. The issue is that the browser throws this exception: Refused to display 'https://demo.docusign.net/' in a frame because it set 'X-Frame-Options' to 'sameorigin'.” This indicates that the URL set by the DocuSign JS has a sameorigin header set, so it can’t be embedded, which defeats the purpose. Does anyone know what is happening here or can help? Appreciate it!
Justin Jiang
Established Contributor
Apr 27, 2024 3:48 PM UTC
The issue you're encountering with embedding a DocuSign URL in an iFrame is due to the 'X-Frame-Options' HTTP header set to 'sameorigin' by DocuSign. This security measure prevents the page from being displayed in a frame on any domain except the same domain as the one the page is on. To resolve this, you might need to adjust your implementation approach. DocuSign provides methods to embed signing ceremonies or sending consoles via iframes, but you need to ensure that you're using the correct URL format provided by specific DocuSign API methods, such as CreateRecipientViewAsync.
For further details, you might want to review DocuSign's guidelines on embedding here.
Welcome to the DocuSign Community and University! Your feedback is immensely appreciated. If this answer resolves your issue, please feel free to give it a Like and mark it as the "Best Answer". This helps others in the community find the information they need. Visit us at http://dsucustomers.docusign.com for more resources and support.
ScottNew VoiceAuthor
Apr 29, 2024 1:10 PM UTC
Thank you for the response, Justin.
I have had embedding the DocuSign in an iFrame working for some time now, but I have to create the iFrame element and set the source. I am obtaining the URL for the document from a call to the createRecipientView REST API. the According to this DocuSign blog, I should be able to use DocuSign JS and focused view to avoid the pitfalls of using an iFrame. I followed the DocusSign embedding documenation and passed the receipient URL to the DocuSign JS loadDocuSign method. The method created an iFrame for me, set the src, and set it as a child under a div I specified, but when the src loads I get the “sameorigin” issue. I am beginning to think this is a bug.
May 30, 2024 11:30 AM UTC
Any update ? I’ve got this error when displaying the generated URL using the focused view. But it works fine on iframe,,
Refused to frame 'https://127.0.0.1:8000/' because it violates the following Content Security Policy directive: "frame-src 'self' https://docucdn-a.akamaihd.net/ https://apps-d.docusign.com https://demo.docusign.net https://account-d.docusign.com https://proof-d.docusign.net https://identity-d.docusign.net https://azure-demo.docusign.com https://content.googleapis.com https://docs.google.com https://players.brightcove.net https://www.youtube.com https://accounts.google.com https://docusign.sjv.io https://apps.usw2.pure.cloud https://docusign.co1.qualtrics.com/ https://sawmill-stage.docusigntest.com https://docusign.okta.com https://demo.forms.docusign.com".
Aug 15, 2024 10:03 PM UTC
I am currently dealing with the same issue. If we are asked to specify frameAncestors, why can’t I properly embed the iframe? The frameAncestors should be added to the CSP directive but they are missing.
samuelhgf
Aug 21, 2024 6:23 PM UTC
If you guys are using Safari, that helped me
https://www.docusign.com/blog/developers/focused-view-safari-ios-oh-my
Samuel França
Aug 11, 2025 10:31 PM UTC
I ran into this issue as well, can you see what src your docusign js iframe is using? For my developer environment the iframe src started with https://apps.docusign.com/embedded-signing which would break against my demo docusign account. The docusign js code tries to determine the src based on the return url you receive, but it kept giving me the wrong one. To fix this I used the code below to display the iframe. Hope this helps.
window.environmentOverride = 'https://apps-d.docusign.com/embedded-signing'
