Oct 14, 2024 6:08 PM UTC
QuickStart Problem With PrivateKey RSA
Hello everyone!
I'm using the eSignature API, and recently all my code has been running into issues with the RSA Private Key. I tried running the standard QuickStart code, but it has the same problem. The error message is: ValueError: Unable to load PEM file. See https://cryptography.io/en/latest/faq/#why-can-t-i-import-my-pem-file for more details. MalformedFraming.
All my code used to work just fine, but now this issue keeps happening. Has anyone else experienced the same problem?
Oct 16, 2024 7:44 AM UTC
I tested it with my Python app created by Quickstart and was able to load the private key without issue. I would recommend you check whether your private key is located in the right place. Also please refer to the "Why can’t I import my PEM file?" section on this page and check if the private key isn’t broken: https://cryptography.io/en/latest/faq/#why-can-t-i-import-my-pem-file%20for%20more%20details.%20MalformedFraming
