Sep 5, 2024 4:39 PM UTC
Programmatic way to authenticate and send out PDFs for signing
Hello. I’m trying to create a back-end system that can automatically retrieve an access token without any user interaction so that it can send out documents for signing. The samples I’ve encountered PDFs for signing have required me to authenticate using my developer account. Is there a way to get an access token programmatically without any user interaction?
I appreciate any help you can provide.
Docusign Alumni
Sep 6, 2024 6:42 PM UTC
Hi Thui,
I’m a Developer Support Engineer here to help you out.
I understand you want to obtain an access token programmatically without user interaction. There is a solution using scopes—these are essentially labels that define the permissions your app can have via the API. One particular scope, "extended," is relevant here and applies specifically to the Authorization Code Grant.
By using refresh tokens along with the extended scope, you can keep a user logged in indefinitely. This is achieved by requesting the extended scope and regularly refreshing the access token.
When you specify the extended scope, each time a refresh token is used, its validity is extended by 30 days.
I’ll send you an article that provides more detailed information on extended scopes and how to implement them.
https://community.docusign.com/esignature-api-63/programmatic-way-to-authenticate-and-send-out-pdfs-for-signing-20285
Best,
Dev/API Team
