Oct 24, 2024 11:36 AM UTC
Power Automate - Add tabs for a recipient on an envelope
Hi All,
In my document i have an anchor string “I:” in multiple places and the connector is adding at all places where it finds “I:”, but when I try to enter some values in those text boxes, same value is being taken automatically in every text boxes in the document.
Sample Image
I entered - Test2 in the first text box and same value is being auto populated in other two text boxes as well.
Can anyone help me on the same?
Regards
Sasikanth
Oct 25, 2024 4:57 PM UTC
@Sasi007
The overriding of fields will occur if the fields have the same data label.
Could you try adding a unique tab label for each field?
You can read more about data labels here: https://support.docusign.com/s/document-item?language=en_US&bundleId=gbo1643332197980&topicId=nas1578456281970.html&_LANG=enus
This is a post with the same question and shows an example of a fix using C#.
https://community.docusign.com/esignature-api-63/is-there-a-way-to-place-two-date-tabs-19791
@Sasi007
