Conversation Starter
Aug 5, 2026 6:27 PM UTC
Performance Delay with Multiple ListStatusChangesAsync Calls Using Custom Fields
We are using the ListStatusChangesAsync API to retrieve DocuSign envelopes for multiple account numbers. For each account number, a separate API request is sent to fetch the related envelope details, including documents and custom fields. All requests are executed in parallel, and the responses are combined into a single result set.
We have observed that the loading time increases as the number of account numbers increases. We would like to understand the following:
  • Does DocuSign apply any throttling or delays when multiple API requests are executed simultaneously?
  • Is there a recommended limit for concurrent API requests?
  • Does retrieving additional information, such as documents and custom fields, significantly affect performance?
  • Is there a more efficient approach for retrieving envelopes associated with multiple account numbers?
Any suggestions or best practices would be greatly appreciated.
Aug 7, 2026 2:41 AM UTC
Hello
  1. Throttling / delays
    • Docusign enforces rate limits, not per-request “sleep” delays.
    • You’ll see this via X-RateLimit-Limit,  headers
  2. Concurrent requests
    •  Keep total calls within the hourly account limit and avoid tight per-envelope polling (≥20-minute intervals for status checks is recommended).
  3. Including documents/custom fields
    • Adding include=documents,custom_fields makes each ListStatusChanges call heavier
    • As you scale accounts/envelopes, this will noticeably increase latency.
  4. More efficient approach
Thankyou
Thanks & Regards
Sai HariPriya Dandamudi | Developer Support Engineer | DocuSign
A picture containing clipartDescription automatically generated
