Apr 17, 2025 2:31 PM UTC
Multiple documents with Auto-Place not using DocumentId
I am creating an envelope using the API and adding multiple documents and using Auto-Place to add the “Sign Here” tabs. The anchor string is the same on both documents but I would like the tabs to only place on the document specified by the “DocumentId” on the tab. This does not seem to work.
Here is example code using the C# SDK:
Is it expected that the SignHere would be added to both documents? If so, how would I prevent that?
	var envelope = new EnvelopeDefinition();
Document doc1 = new Document
DocumentBase64 = doc1DocxBytesBase64,
Name = "docusign-test",
FileExtension = "docx",
DocumentId = "1",
Document doc2 = new Document
DocumentBase64 = doc2DocxBytesBase64,
Name = "docusign-test2",
DocumentId = "2",
envelope.Documents = new List<Document> { doc1, doc2 };
var signer = new Signer();
signer.Name = "Test Name";
signer.Email = "test@test.com";
signer.RecipientId = "1";
SignHere signHere1 = new SignHere
AnchorString = "\\s1\\",
DocumentId = "1"
Tabs signer1Tabs = new Tabs
SignHereTabs = new List<SignHere> { signHere1 },
signer.Tabs = signer1Tabs;
var recipients = new Recipients();
recipients.Signers = [signer];
envelope.Recipients = recipients;
envelope.Status = "sent";
envelope.EmailSubject = "This is a test";
envelopeApi.CreateEnvelope(AccountId, envelope);
Apr 22, 2025 3:44 PM UTC
Yes that is the case
Apr 22, 2025 3:28 PM UTC
If you have the same anchor tags across the envelope, this will cause the duplicates. If you don’t want duplucates then you should use unique anchor tags on each document.
The following article will explain that:
How to fix duplicate anchor tags
bbeardNewcomerAuthor
Apr 22, 2025 3:35 PM UTC
So the DocumentId on the SignHere tab doesn’t mean anything?
