Jun 1, 2026 1:35 PM UTC
Issue Summary for DocuSign
We are facing an issue with the SuccessFactors (SF) to DocuSign connector integration for offer letters.
Current Process:
  1. The recruiter sends the offer letter from SuccessFactors.
  2. The candidate successfully receives the offer letter from DocuSign.
  3. The candidate reviews, signs, and submits the offer letter.
Issue Observed:
After the candidate completes the signing process and submits the document, the candidate is expected to receive a copy of the fully executed/signed offer letter. However, the candidate is not receiving the signed offer letter copy via email.
Request:
Could you please investigate the integration/workflow and confirm why the completed signed document is not being delivered to the candidate after successful submission? Additionally, please advise if any DocuSign notification or distribution settings need to be configured or updated.
Note: Configuration was changed as per DocuSign docment
Jun 2, 2026 4:39 PM UTC
​@Dillip Kumar
The most likely cause is a DocuSign completion email / envelope delivery configuration issue, or the candidate is signing through an embedded/captive signing flow where completion emails may be suppressed.  Are the even receiving the notification email?  Is this an embedded/captive signing flow?
​@Dillip Kumar
Jun 2, 2026 9:32 PM UTC
Hi ​@Dillip Kumar
As John said, check your Envelope Delivery configuration.
Log on to Docusign and select Admin > Signing Settings > Check the Envelope Delivery section. Make sure that "Suppress emails to embedded signers" is deselected > Select "Send completion emails to embedded signers" > Save.
Jun 26, 2026 4:52 AM UTC
Hi ​@Dillip Kumar
Hi ​@Iandro.Simoes.
We have completed the above configuration on the system, but the issue still persists. Could you please verify whether this issue is related to our credentials or if there is a system-side problem?Add as many details as possible, by providing details you’ll make it easier for others to reply
Thanks,
