Dec 16, 2024 5:41 AM UTC
Focus View in Angular doesn't work
Import in index.html
<script src='https://js-d.docusign.com/bundle.js'></script>
In signing page component:
import { Component, OnInit, input, AfterViewInit } from '@angular/core';
import { Input } from '@angular/core';
import { ActivatedRoute } from '@angular/router';
declare const DocuSign: any;
@Component({
selector: 'app-focused-view-signing',
imports: [],
templateUrl: './focused-view-signing.component.html',
styleUrls: ['./focused-view-signing.component.css']
export class FocusedViewSigningComponent implements AfterViewInit {
integrationKey: string = 'xxxx'; // Replace with your integration key
constructor(private route: ActivatedRoute,) { }
ngAfterViewInit() {
const url = this.route.snapshot.paramMap.get('url');
console.log('Input URL:', url);
DocuSign.loadDocuSign(this.integrationKey)
.then((docusign: any) => {
const signing = docusign.signing({
url,
displayFormat: 'focused',
style: {
branding: {
primaryButton: {
backgroundColor: '#333',
color: '#fff',
signingNavigationButton: {
finishText: 'You have finished the document! Hooray!',
position: 'bottom-center'
signing.on('ready', (event: any) => {
console.log('UI is rendered');
signing.on('sessionEnd', (event: any) => {
console.log('sessionend', event);
signing.mount('#agreement');
.catch((ex: any) => {
console.error('Error loading DocuSign:', ex);
Result:
I got envelope properly but can’t sign it. The page was not interactive.
There’re some error or warning in console:
  1. Error importing mockServiceWorker.js NetworkError: Failed to execute 'importScripts' on 'WorkerGlobalScope': Failed to import 'https://docutest-a.akamaihd.net/integration/1ds/libs/msw/2.2.11/lib/mockServiceWorker.js'. importScripts() of new scripts after service worker installation is not allowed.
  2. translation error (1ds-bindle.js)
  3. [Violation] Permissions policy violation: Geolocation access has been blocked because of a permissions policy applied to the current document. See https://goo.gl/EuHzyv for more details.
  4. Warning: displayFormat focused cannot be used with ERSD
Hengfeng Ge
Hero
Hero
Dec 16, 2024 10:19 AM UTC
please confirm the name/email/clientuserid for this recipient is correct.
FreeLink/甫连信息
🌍 Docusign Partner | Partner Profile
🏆 Docusign 2024 APAC Reseller Growth Partner of the Year
🌟 The only Docusign Partner globally certified as both a Certified eSignature Administrator and eSignature Technical Consultant.
📊 Docusign Community Leaderboard Top 5 contributor.
🚀 Expertise in Docusign integrations with on-premises systems for leading enterprises across various industries.
evanLiNew VoiceAuthor
Dec 17, 2024 2:14 AM UTC
FreeLink/甫连信息
I have implemented three types of embedded signing:
  1. Redirect (default)
  2. Using <iframe>
  3. Using focus view
All those approaches is using exactly the same envelope definition. But only the third one is not working.
For focus view, I define request view with:
viewRequest.frameAncestors =
[environment.liffOrigin, 'https://apps-d.docusign.com', 'http://localhost:3000'];
viewRequest.messageOrigins = ['https://apps-d.docusign.com'];
Thanks for your help again!
Dec 17, 2024 6:49 AM UTC
I don't see any particular issues with your code. As the signing page is loaded but not interactive, I assume the issue might be related to the browser.
Based on our assessment, we suggest initiating a support case with DocuSign. The support team will then guide you through the necessary steps via the case. Here's the link to open the support case with DocuSign: https://support.docusign.com/s/articles/How-Do-I-Open-a-Case-in-the-DocuSign-Support-Center?language=en_US
