Custom Envelope Fields - Limiting/Cleaning Sender Input
Setup:
I’m A DocuSign Admin, and my organization uses a Custom Envelope Field to collect a 5 or 6 digit account number that DocuSign Connect then sends to our Document repository where that number is used to route the documents into the correct account.
Issue:
Sometimes staff will have a typo in the CEF such as a letter, period, or leading space on the account number.
This causes the file to not be routed correctly by our repository.
Question:
Is there a way to force the CEF to allow numbers, or to have Docusign Connect clean the CEF so it does not pass non-number data entry into our repository?
Back to Docusign.com
