Jun 17, 2024 9:24 PM UTC
Converting eSignature calls to eNotary calls
I haven’t dug into the eNotary much yet, but one of our teams is looking to implement RON into their workflows.  The contracts are currently sent with the eSignatue api utilizing the C# SDK.  My question is how difficult it is to change this to use the eNotary API are there any guides to do this without having to rebuild all the existing code or is it just as simple as enabling the document for notary when I send the API call?
Jun 19, 2024 11:48 PM UTC
Hello Team
We have Docusign eNotary API https://developers.docusign.com/docs/esign-rest-api/reference/notary/notary/ & this will help you to easily integrate within your esignature API's with out taking longer time.
Thanks & Regards
Sai HariPriya Dandamudi | Developer Support Engineer | DocuSign
