Best practice for DocuSign templates when recipients and signing order vary
We are integrating DocuSign with ServiceNow and would like to understand the recommended way to design DocuSign templates.
We have the same type of business document, but the recipient and signing order can vary for each transaction.
For example:
- The internal recipient can be an individual user or a Signing Group.
- The Signing Group can be Legal or General Affairs.
- The routing order can be either:
- Internal recipient → External recipient
- External recipient → Internal recipient
The document itself and the basic recipient roles are the same.
In this scenario, what is the recommended template design?
- Should we create separate templates for each Signing Group?
- Should we create separate templates for each routing order?
- Or is it better to keep one common template and set the actual recipient/Signing Group and routing order dynamically through the API?
We would like to avoid creating unnecessary templates and keep the integration maintainable.
Thank you for any advice or examples of similar implementations.
Best Regards,
Back to Docusign.com
